im ready to purchase some suspension, some people are telling me that lowering springs and struts are the way to go for nyc streets, but i also heard that only coilovers can be dropped low enough so you tuck the wheels under the fenders for that 0 offset look. which theory is true?
suspension for nyc streets
Can you give us an idea of the new york streets?
I'm going to guess they're like the rest of the nations and say they're pretty bad.
If that's the case, I'd stay stock, as I have done. Lowering your car on coilovers will just make it more likely to scrape.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by GeoffM View PostCan you give us an idea of the new york streets?
MY advice is to stay STOCK and invest in a h22 motor to keep up with those cabs.
yes we suffer from a bit of road rage we are just always in a rush, i will rephrase my question, which suspension set up is best for bumpy, pot hole filled roads, i want to go coilovers but im a bit nervous about doin so for teins are about $700ish i dont want to have to replace 700 bucks worth of coilovers every 6 monthes, and stock just looks ugly, and i want to show these civic and teg dudes that cb7's still got it lol
Koni Yellow shocks... also known as Koni Sports. They have a lifetime warranty, and will handle ANY drop.
For pothole filled streets (I know them well... I spend 10 hours a day on North Jersey streets...) I would suggest a mild drop, with a low spring rate. H&R Sport or Neuspeed Sport springs would be a great choice. Tein S Tech would be another good one.
Don't bother with coilovers. If you blow one, you're replacing the whole unit. If you get a spring/shock setup, and you blow a shock... you're just replacing a shock. If you get Konis, and use the warranty, you'll be replacing them for free.
I keep forgetting that kit exists! It's a great one... very much like what I have on my car now, though slightly better (since the shocks are valved for the springs specifically.) Neuspeed has a similar setup with their race springs (slightly lower drop.)
And really, a 0 offset? That trend is just about dead, you know... your wheels are going to be poking straight out, looking dumb as hell.
