Using a switch to diag. S/D4 Errors?
    Hey guys, I was reading the "ENG: Diagnose a Check Engine Light and S/D4 errors. " thread here and a few of the people replied saying rather than use a paper clip, they used a switch to diagnose their S/D4 errors.
    Does anyone have any pictures/layouts/ or schematics they can share? I wasn't exactly sure what to type in a search engine for this.
    ||91 Accord EX|| All of my images are hosted courtesy of imageShack.com
    Door-Sensor fix (DIY)||Interfacing Arduino to Power locks
    RICE = Race Inspired Cosmetic Enhancement.
    "The greatest advantage of speaking the truth is that you don't have to remember what you said." - unknown
    "That's the funny thing about parts that break... they're never broken until they are!" -deevergote
    Wiring a switch in place of the service connector is as easy as removing the oem diagnostics connector, and connecting each wire (theres only 2) to the different poles/connectors on the switch. I would probably just zip tie it in place behind the kick panel, or if you wanted you could cut and mount the switch wherever you like.
    If you need information on the typical chassis wiring of our cars, look at: http://www.cb7tuner.com/vbb/showthread.php?t=184559
      You could probably just stick the ends of a switch into the connector, without even needing to remove it.
      The paperclip works just fine, though... and if you keep up with maintenance, you shouldn't need to diagnose error codes all that often!
        True that, but with the way some peoples luck are, when there in a jam, no paper clip can be found. To prevent that situation you could always just tape a paperclip to the service connector, eg. paper clip holder.
          or get a matching 2-pin connector, its the same as the ones used for the front door speakers. use that to connect to the OEM connector, and run each of the 2 wires to either side of a switch. i have one mounted on the passenger kickpanel, but unfortunately i dont have a pic to post.
            Now thats what I call pure gold, I didn't know the location to aquire the other matching connector.
