What Tire sizes are most cb7s running
    I was just curious, because I'm running 205/40r17 in the front and 225/45r17 in the rear. And I don't really like the way it looks. I know the front tires are close to oem size but to me it just looks a little funny. So any suggestions
    205/45 is ideal
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      My 10th edition came stock with 195/60R15. They work pretty well for me
      1993 10th Anniversary MRT
      Originally posted by The G-Man
      For that money, yes. But my dick isn't big enough for that shit.
      List of all my cars to date
        Yeah 205/45 is what Im going for. But my freinds and family like the look now, that's really why I asked; to see if anyone else is running something similar( side wall wise).
          It all depends on the size and offset of the wheel. Sometimes a narrow tire is necessary for clearance.
          For a 17x7.5" (a very common size) wheel that is the correct offset for the car (I consider anything from +38 to +42 to be "correct") then yes, a 205/45/17 is a very good size. Most tire websites suggest 205/40/17, but I've found that to provide very little protection for the wheel. I've run tires as wide as 215. 225 would probably prove to be too much rubber, providing a very "squishy" ride as it bulged over the edge of the rim.
            All depends on the size of rim... Drop... And look overall that you are looking for.
              This can be very helpful when trying to figure out what tire sizes can go on or cars. For figuring out what the speedometer difference will be use an original tire/wheel size of 185/70-14 (Stock 14") or 195/60-15 (Stock 15")
              http://www.tacomaworld.com/forum/tirecalc.php
              Best tire calculator I've found
              90 LX 5spd 2dr (2011-2014)
              93 EX 5spd 2dr (2013-2015)
              92 LX 5spd 2dr (2015-present)
                First off I apologize to thread jack but it's related to the OP question.
                Just out of curiousity I know the suspension is the same on 4th & 5th gens so essentially the tires sizes are similar ,correct?
                So it should be safe to say I could run 215/50 R15 safely on my 5th gen wagon? Or would 205/55 R15 be a better route for daily use?
                BTW- I've got some 7 spoke Prelude Si's on and don't plan on changing them.
                  205/45 will throw speedo off
                  COUPE K24
                    On my 17's I'm running 215/45 s and they work good. personally I've found 16's with 195/50 or 205/50 to work better (all preference), not as CLUNKY. but stock is always great.
                    BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
                    BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
                    Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
                    CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
                      on my 15's i run a 195/60
                      STANCE|WORKS
                        for 15s 205/50
                        16s 205/40
                          Is this Tracie? I'm stalkin you, JK. Do you you have any problems with tires rubbing?
                            You guys need to include rim sizes with your tire sizes...
                            205/55/r15 is a perfect size for a stock CB and won't affect the speedometer at all
                            205/55/r16 does however affect the speedometer by 2-5mph.
                              I've had a couple of setups on my CB and I love the 205/50/16 the best!!!....
