Rust Colored Splatter Inside Bay..
    This might be a dumb question, but has anyone seen this before? It could be nothing, but im pretty certain it isnt dirt or mud, just because of where its at and the fact it didnt come off easily. Any comments would be helpful.
    CB7 93 LX AT.
    MY_CB7
    Could be coffee ??
    Hopefully, it's not a mixture of engine oil and antifreeze because that would mean a blown head gasket. Looks like it could have shot out from the water pipe you disconnected from the throttle body.
    Taste it..
      Taste it..[/QUOTE]
      I like the way this guy thinks... but I have the same problem and I think it might just be mud off the road kinda splashing up. That was my best guess
        Heater core hoses run near there. Sometimes those hoses just burst if not replaced at a proper time which could cause something like that to happen. As for the color of the splatter, if whoever had the car at the time just ran water instead without coolant, then it would look like that. Either that or a blown head gasket like previously stated. I would check my coolant an make sure it's not a blown head gasket just for peace of mind.
        Purchased From: busak87, GunRunner, Bruce Banner, Itstatcb7kid707, tJoods, DannyD
        The Caravan 2015
        MRT:http://www.cb7tuner.com/vbb/showthread.php?t=180919
          ive seen that before, and its not mud. its burnt coolant, probably from the heater hose, but like everybody said, check the HG
            also stop leak turns coolant brown......have seen it tons of times
              oh well thats good to know. would a new hose back there on the heater core fix it?
                thanks for the comments, ill take another look down there to see if anything looks out of place. i have used some prestone stop leak a while ago for a radiator leak, which it seemed to help. my coolant looks to be a normal color and my radiator and reservoir and staying full. the car seems to be running normal without overheating (other then my bad idle i cant seem to fix)
                CB7 93 LX AT.
                MY_CB7
                  Looks like rust from inside the engine... If you put water in your cooling system for long periods of time this happens..Maybe from the previous owner if it wasn't you
                    If its not coolant, look at your rear motor mount. Its hydrolic fluid. I can almost guarantee that.
                    And seal up that wire....extra resistance on that circuit can cause issues.
                    Retro!
                    Hater
                      that was my original thought.. i have noticed extra vibration at idle and while shifting (automatic). i have recently replaced my torque mount in the front since the rubber was shot and was thinking it was about time for a new hydrolic rear mount. is there a way to test for a bad mount besides reving it in gear? or would it be obvious if it were failing? i have been through hell trying to get my car to idle perfect (mysterious vac. leak or something) but am starting to think my mount may be more of the problem..
                      CB7 93 LX AT.
                      MY_CB7
                        When my old CB blew a headgasket and THAT happened. then my radiator threw up all this water and crap. It was bad lol. Then my car was stolen shortly after.
                        The problem also turned out (in my case) a bad radiator hose coupled with that blown head gasket
                          Shine a light from the passenger side of the engine bay and look at the mount in the middle to see if there are any tears or abnormal amount of crap in there. It should look dry and not wet.
                          Retro!
                          Hater
                            hmmm well im really hoping its not my head gasket.. everything seems normal, car pulls hard, not burning or losing any coolant, not overheating.. oil color seems normal.. i guess ill investigate a bit deeper.. thanks for the comments guys
                            CB7 93 LX AT.
                            MY_CB7
                              So the problem worked itself out then? lol
                              1992 Accord Wagon (RETIRED)
