Lets talk resistor box and grounding plug
    Ok I had this bright idea about eliminating the resistor box and using a ground plug from another harness.
    Before I do anything I want to understand whats in the box exactly. What I did was open up the box to see whats in it, so I opened it and saw this
    Now I noticed that this cant be removed looks to be fused or glued together, and if you look at the harness to it it seems to have gtound wires and a red wire. but if anyone happens to know what wires go to it, knows that the wires would be the negative side of the injector plugs harness, the positve wires lead back to passenger side shock tower leading to the ECU plug.
    So what I want to know is resistor a junction ground box since negative wires go to it.
    If my theory is correct then what I can do is de pin the negative side of the injector plugs and run them into this ground plug such as this
    As you can see its just a plug.
    _______________________________
    Now before people say whats the point of this then dont bother posting no offense to those that will think it,
    I did a complete wire tuck including makin my own engine harness and will be running it in the cabin of my cb, the resistor box wont be seen but sits to where it cant be secured (MOVES AROUND). I just want a clearner look that I won have to worry about falling or moving around. Also for those that are doing wire tucks and hate the resistor box post up yout idea's or theories
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    not sure about the resistior box, but your bay is looking real nice.
      i actually made my own diagnostic box. it's really simple one power in and four out after the resistance. you are putting resistors right? unless you're going to be running high impedence injectors.
      http://youtu.be/0tMzbPJMvYI
        yeah its just 4 resistors embedded in epoxy. 1 power line in, 4 outgoing lines to the injectors.
        of you want to eliminate it, use inline resistors (may as well just tuck the oem box) or get some high-impedance (OBD2) injectors, they basically have built-in resistors... that way you would be able to remove the resistor box by splicing all 5 pins together (thats what I did)
        wes, i like the injector-cut box!
