I did a auto to 5spd swap. due that i cracked my auto trans.
problem is i started the car and check engine light came on. Pulled the codes.
5,10, 21,22, 36.
im mostly worried about 5,10. i know vtec, pressure and knock isnt hooked. and 36 is traction control found on the jdm ecus.
All my vacuum lines are hooked up etc. Engine dosnt have crazy idle.
I guess what i wanna ask is will i be ok to run the car like this, having code 5 and 10?
The most i would run this car would be point a to b less then 5 miles.
any help would be appreciated.
5,10, 21,22, 36.
