brakes sticking please help
    i have a 92 accord ex-r
    my front brakes are sticking and i was reading a thread about a month ago and i think they said it may be the master cylinder
    but also if im no mistaken when i bled my brakes i think it was the 2 front 1's that wouldnt spit fluid or air out
    would it be a master cylinder problem or would it be air in the lines that wont come out because the valve wont open properly?
    Is there a abs light on?
      Grease your slide pins
      Check the lines
      (Collapsed, air in them, etc)
      Check the caliper
      Master cylinder
      First thing:
      Make sure you don't have to much brake fluid. If you do it'll cause your brakes to drag.
      MRT
      sneaky motherfucker
        Or maybe you or someone put the pads in the wrong way
          IIRC, one of the pads has a big metal piece on it. I don't see how you could get it in the wrong way....
          MRT
          sneaky motherfucker
            What is the car doing that makes you think the brakes are sticking
              exactly
                thanks for all the help hopefully i can get it fixed
                and i know theyre sticking cause when the front is in the air the tires are alittle heavier to move by hand and you can hear the brakes on the rotor
                and when youre not giving any gas it slows down more then normal
                  Most likely:
                  Upper or lower caliper slide pins are sticking. Take them out, clean them off, regrease with high temp synthetic brake grease, and reinstall. Make sure the boot that protects them is in good shape, if not replace it.
                  Don't let anyone sell you a $400 brake job for this, it's like a 30 minute job. $60-$80 if you are paying someone to do it, unless they can show you fucked up rotors etc. just have them do the slide pins.
