PCV Valve grommet
    PCV Valve grommet
    I got a new one in the spring, today I opened up the hood and saw the PCV valve was sort of popped out.
    Turns out the top portion of the grommet is mostly torn off.
    I'll order a replacement tomorrow, but I'm just wondering how this might've happened.
    MRT
    sneaky motherfucker
    Its 20ish years old
      Originally posted by ChIoVnIdCa View Post
      Its 20ish years old
      It's 3 months old.
      MRT
      sneaky motherfucker
        you put it in wrong.
        COUPE K24
          It may have gotten torn installing it and just not noticed. Its not really a stressed piece unless your stretching your hose tight.
            I just pushed it in....
            That seems more likely.
            MRT
            sneaky motherfucker
              buy a new one, when you install it, put a little vasoline on it. seriously. i do this on all rubber seals and o rings. it helps everything go together without tearing and even allows a better seal. also keeps the rubber from drying out and getting all hard
              MRT: http://www.cb7tuner.com/vbb/showthread.php?t=183959
