Can't shift out of park
    I can't seem to figure out what is wrong.
    If put into park and press brake than can't shit out of park.
    Had to keep it in neutral to avoid that.
    What could it be? Tranny?
    The lock switch is bad.
    If you put the key in does it unlock manually?
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
      lock switch?
      Yes, if I put key by that hole near shift it will unlock.
        Originally posted by avaaj View Post
        lock switch?
        I believe that's the shift interlock control/switch.
        Buy/download a manual and it'll tell you more. Or wait for an answer on here.
        MRT
        sneaky motherfucker
          http://www.cb7tuner.com/vbb/showthread.php?t=179121
            Thanks.
            Wish there was picture.
            I'm more of a visual guy.
              It's on the right side and visible once the console is removed.
                Do you have brake lights?
                  Does your horn work?
                  The lockout solenoid is on the same fuse as the horn. Another member had the same problem as you and it turned out the fuse was bad.
                    I had a civic that did the same thing but it was the shift cable
                      A few days ago I couldn't shift out of Park. I got towed & had the Transmission Cable replaced. Now the gear shifts fine.
