car wont start
    car wont start
    hey guys
    so my 92 wont start and the cel stays on and it wont read no codes but ive changed the dizzy coil ecu and fuse box but still nothing its getting no spark or fuel the pump isnt kicking on. the power going to the dizzy and coil its just not putting out spark anyone kno what it might be
    main relay
    COUPE K24
      Does it crank?
      MRT
      sneaky motherfucker
        Originally posted by '93CB7Ex View Post
        main relay
        x2 when my main relay went my cel stayed on when the ignition is on.
        1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
        Originally posted by keepinitclean
        I give it 2 weeks before you sell it.
          yea it just cranks and cranks
          which relay u think it would be
            main
            COUPE K24
              yea thats what mine did i was putting out of the drive way and it actted like it was missing then died and wont start back now
                where is the main at
                  behind dash half way up. its usually gray case with a red bottom. open it up and look for broken solder joints.
                  COUPE K24
                    http://www.cb7tuner.com/vbb/showthread.php?t=53888
                    ^^There^^
                      Take off the cover under the steering wheel.
                      Take out the cc module.
                      The main relay is above it. Little plastic gray box.
                      MRT
                      sneaky motherfucker
                        aright cool guys i will try that and hopefully it works if not i will come back to u guys
                          i swear after i did my tuck ive had more problems with this thing
                            Use the edit button to combine posts.
                            Expect problems when you play with wires.
                            MRT
                            sneaky motherfucker
                              yea i kno but i only messed with the lighting wires cause everything is under the dash fuse box carcal can vacume box everything thats why i took out my heater so i didnt have to cut in to main wires but its ok i will get her fixed back up but thanks guys
