Car stalling
    Car stalling
    Hello, all. I have a 1993 Accord, Automatic. 240,000 miles. This problem has happened a couple times... So, the first time it happened, I was driving like 20 miles from my home....Got to the destination, everything is fine. On the way back, I was kinda low on gas, but the gas light hadn't come on yet; I'm driving along and it kinda surges a couple of times, so I let off the accelerator...then a few minutes later is surges a lot and stalls with the engine light on.
    Second time, I go to my doctor who is 30 miles away. On the way there, great, no problem. On the way back it surges & stalls again, this time no engine light. I wait five minutes, turn it back on and it's good. Full tank of gas.
    I can turn the car back on afterward and keep going. Sometimes I'll have to wait a minute to turn back on. Another observation, my RPM's are very erratic, I dunno if my sensor is messed up, but it's always "floating" for lack of a better term. It works good for anything less than 10 miles...
    Facebook.
    Xbox Live: Call Of Duty4: Unt0uchable15 --I'm a beast!
    Member Ride
    when was the last time you changed your o2 sensor? it sounds like that might be the problem. normaly O2 sensor problem will throw a code, but sometimes it doesn't.
      my car use to do that with a bad o2 sensor but i'd try cleaning out your IACV
        ^for real man? GTFO. and the other guys are right, your car isnt getting enough oxygen so the engine just dies.
        Originally posted by rickyduckworth
        that's pretty interesting. when i get that bored i just watch porn and go to sleep
          It's funny, because he shares an IP address with you... and that IP address is about to get banned.
            its might be a kid in my school? i browse at school. i dont come on here to bullshit.
              Have not checked the O2 Sensor. Do you think it could be the fuel pump?
              Facebook.
              Member Ride
                Were you posting this from school? The ip matched at the time you were both posting this morning.
                My apologies to the op for troll hunting in this thread...
                  Even though I apologized, please do not delete a thread while I am conversing with another member. Thanks.
                    This makes me think it's your ignitor/ignition coil.
                    The erratic RPMs are usually due to that, and the distance/time could be because it's overheating.
                    MRT
                    sneaky motherfucker
                      distributor... mine had a pick up go bad.
                        I think the OP is done with this thread. He had previously deleted it... I just un-deleted it so I could get a response from sohc4door.
