My car is idleing at 100 to 200 rpms. I can't find any vaccum leaks. Any one know why
idle very low
That minimum line is actually 500 rpms.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
I haven't done a full tune up. Just spark plugs and new air filter. The car was fine a few days ago. Then one day just drops the rpms.and it isn't. Chugging it feels fine. Give it some gas and it goes like normal. And deevergote ill go read that see what I can do. Oh an could it be the idle air control valve gone bad???.
Originally posted by G-Series View PostOn the Throttle body there is a Idle screw that has a Flathead top on it. If that does not work then it might be timing or a Vacum Leak.....
Mine doesn't drop that low unless i give it gas and when i let go of the pedal it drops down till it almost turns off but i think it idles way to low because it shakes like its about to stall.
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Originally posted by Ernestox6 View PostHe shouldn't have to adjust anything. If his idle dropped that low there is a serious issue. I have the same problem now with my f22 prelude that started after I raced my friends rx7. I swapped out my iacv and it didn't help. Im gong to swap my fitv to see what happens. Also, it acts normal with engine cold and idle adjustments don't help.
Most vac leaks will cause higher idle problems, because it is receiving more air than whats being measured. That will also cause surging. (obviously this isn't your issue) And if your dead set on it for some odd reason, get some carb cleaner while the car is running and spray it around where you may think it's leaking, it's rev really high if so.
My first thought is that your idle screw is improperly set not allowing enough air to be combusted.
The IACV could have some to do with this, but every honda i had i deleted this and never had any type of idle issue. (that is not to say your engine could do the same)
Little things i would check first.
plugs, are they clean?
throttle cable is it properly adjusted?
idle screw is it allowing the correct amount of air to enter? this is important for driving and letting off the throttle as well as you don't want your car to fall on it's face everytime you let off the gas.
verify correct fuel pressure.
clean iacv and reinstall.
remove egr valve and see if it's stopped up.Last edited by KeeleDesign; 05-30-2011, 11:29 AM."Self Renewed"
I've checked my plugs and replaced them they were clean. Sprayed carb cleaner on the vaccum lines. Nothing happened. Tryed reseting base idle nothing happened . No shuttering. When I give it gas it accelerates slow for about 2 seconds then drives normal. When idleing at 200 rpms no chug no shutter nothing. Me and my friend can not find any reason at all. Why the car is doing this. I even cleaned the iacv and ficv. And hoses still no change. I thing my timing screwed up. But the car was sitting still when the problem started.
