well My car kept dieing when I stop so I made this thread >http://cb7tuner.com/vbb/showthread.php?t=177328.
It was not alot of help.
Here is a list of all of the stuff I replaced and or did trying to fix it.
Fuel pump is new.
ngk plugs
wires
cleaned the cap and rotor
replaced the fuel pressure regulator
Replaces the iacv & gasket
egr valve& gasket
Air filter
fuel filter
igniter inside the distributer
main relay
cleaned and replaced some of the wires in the distributer
and the list go's on.
It it getting worse now. I use to be able to stop it form dieing now it just dose and alot more then it use to. Its so bad I cant drive it around the block, Now its super hard to start. It has a bad misfire but only under load at 1500 rpm's. So I can rev it to 1500 it N or P and it acts fine but when I put in in gear then It misfires... I went and got a new coil off ebay and it wont be here for a week. What do you guys think will the coil fix it or what else could it be?
Fuel pump is new.
ngk plugs
wires
egr valve& gasket
Air filter
fuel filter
main relay
