im leaking oil where can it be coming from?
    i am leaking oil from somewhere. i seen it coming from the oil pan gasket and changed it. but its hits my exhaust and smokes bad idk every where else to look. does any1 have any suggestions
    Can you give us a hint? Like, front, back, sides?
    Exhaust goes front to back. Valve cover could be leaking down on to it, the headgasket could be leaking into it, the oil pan gasket could be leaking onto it. Same goes for the back.
    MRT
    sneaky motherfucker
      If it's leaking onto your exhaust then it could be the oil pressure sensor or the oil cooler gasket if you have an oil cooler.
      Yes my name is Dang, Don't use in vain
      1992 Honda Accord EX (Coupe/Bordeaux/Auto)
      1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
      2008 Honda Accord EXL (Coupe/SanMarino/6spd)
        its coming from the back off the motor and i changed the oil pan gasket and it still leaks just as bad
          OEM gasket?
          MRT
          sneaky motherfucker
            OEM gasket?
            ya the only other thing i can think of is the oil filter maybe? is there anything else it could come from
              As well as everything listed above. If it's the oil filter, the filter is either very old and the seal has failed or somebody didn't make sure the old one came off.
              Degrease your engine and look for the fresh leaks.
              MRT
              sneaky motherfucker
                +1 and if you have access to an "elevator" (sorry i don't know how you name it) to put your car on, it will be better cause you can start your car and look under safety, and protect your eyes!
                -Sorry if my english is bad, i try to improve it and do my best to be understood
                -Soon, you will come back to live...
                Bought from: Jack Lee ,Tommi ,408cb7 , xkjnboix
                  theres a new oil filter and dome cover gasket to befor i did the oil pan gasket
                    which engine do you have?
                      and it leaking on to my exhaust from the the backof the motor next to the fire wall
                        the stock f22a1
                          It may be the oil sender sensing unit or the speedometer head, I think that's what its called, may have to get back to you.It sits underneath and a little behind the dizzy and its easy to replace.Mine broke off the bracket and made a mess.
                            is there anyway you can send a pic of the part
                              I can pic mail it to you later when I'm off work.my computers down so I'm using my phone to post and I'm not sure how to post pics with my phone.if you want you can pm your # or maybe someone can post a pic.I just got mine faulty part at the junkyard.its small and inexpensive.
