Where is it? The time has come for my car to start doing it and I can't seem to find it. I looked in the beginner technical stickies and the DIY stickies.
Honda Idle sticky
Honda Idle sticky
MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfuckerTags: None
2nd link in this thread under FAQ'S
Which happens to be found in the "Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST" sticky
My 5.7 LS1 Holden Ute
I read that, it was published by the man who set my base idle. As far as I know, it's correct.
My problem is bouncing idle. I thought that was a FITV issue. Is it, or should I reset my idle?MRT
Originally posted by GeoffMisiak View PostI read that, it was published by the man who set my base idle. As far as I know, it's correct.
I'm sure you are intelligent enough to find the thread you are looking for yourself . . .
Or should I do it for you?
http://www.cb7tuner.com/vbb/showthre...highlight=fitv
http://www.cb7tuner.com/vbb/showthre...highlight=idle
Which one did you want?
This one should be helpful:
I always assumed the surging idle was due to a FITV problem and that there should be a sticky somewhere. I never looked into it.
Edit:
I made a dedicated thread with much more detail here:
http://www.cb7tuner.com/vbb/showthread.php?t=177619Last edited by GeoffM; 05-06-2011, 08:29 PM.MRT
