Changed ash tray light and car died...
    OK, could this be possibly the reason or is it just coincidence? I changed my burned out ash tray light on my 92 Accord EX coupe and I started it, drove around the corner and it just quit. Tried to restart, it tries but will not turn over. Everyone says the bulb is a 74 but it was too big to fit so I put a 73 in it which fit perfectly and lit perfectly. The battery was replaced last fall, I am having it and the alternator tested right now. It was driving awesome before this happened. This is crazy, surely it was not the 73 bulb...someone reassure me please.
    If I were you, I'd hope it was the bulb. Because if it isn't, then you have something else wrong!
    I think if the it was the bulb you would just blow a fuse.
    MRT
    sneaky motherfucker
      I was thinking the same thing that the fuse would blow. I know it sounds funny but I almost hope it is not the bulb because then I would feel unbelievably stupid for doing that. I am going to drive my car a long time more and I don't mind paying to get things fixed on it or fixing things myself, comes with the territory on a car this old and it is far less expensive than buying a new car. Thanks for the reply.
        Then you better hope it was not the timing belt that's worse i don't think it's the bulb because I have bigger bulbs on my ashtray and floor shifter light so it's most likey not the problem with the bulb good luck
        Destiny Struggles To Reassert The Pattern That Was Meant To Be. Also Some Of These Members Are Wise Guys With There Wise Guy Answers . Also only inexperienced drivers put donuts in front . You can follow me but it's going to hurt!
          It wouldn't cause your car to stop like that. Does it crank over? Did you check for spark/fuel? Also check your starter. If your starter is good and it doesent turn the engine over then your motor is locked up.. This happened to my black coupe it died and when trying to start it it will just click click and the oil dipstick was wrapped around the crank = [
          Originally posted by keepinitclean
          I give it 2 weeks before you sell it.
            does the engine crank when you attempt to start it?
            if so...:
            check to see that you are getting fuel
            crank over the motor and pull a spark plug out and smell it, you should smell gas
            check to see that you are getting spark
            take that same spark plug you just smelled, hook it up to the wire and ground it out to something (the motor). have someone crank the engine, look for spark (easiest in dark)
            check for compression
            rent/buy etc a compression gauge if you have terribly low numbers or a 0, then chances are you broke your timing belt and bent your valves, as this is an interference engine, the valves intefere with the pistons when they are not moving in unison, therefore bending a valve usually. ( I guess it could punch holes in the pistons?)
            as for the dipstick around the crank; HOW? lol damn that would suck
              I dont know how it happens but it does when the bottom of your motor goes = [ it did suck but got me a new cb so im good lol
                Also forgot to mention keep us updated on your car!
