Improving Gas Mileage
    As everyone who owns an accord knows, mileage is the shits. Has anyone achieved a near 30mpg in the city with one of these. If so what modifications do you have? Did you tune it?
    I think that with quality intake, header, and exhaust(including removed cat) + a chipped and tuned ecu with EGR and EVAP turned off it should be possible.
    What do you think?
    30 city would be almost impossible.
    COUPE K24
      ^^^^^ impposible for our accord...but pretty easy to maintain for those 1.5, 1.6 vehicles...lmao
      VS
      Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
      MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
      1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
      MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
        So that's it eh? No chance? What's the most you guys have got in the city?
          i do mostly highway and get 33 mpg easy.
          COUPE K24
            pump full tank and try driving like a grandma... go really soft on the gas pedal.
            Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
              Got 22mpg in the city with my exr automatic driving this way which is right on par with the factory claimed mileage
                **4,500th pOst**
                I never have a full tank of gas to know how much mpg's I have, I forgot the calculation for it anyways, I was told is to be a full tank..
                I have a bad 02. So I no my mpg's r low I can even smell the gas, once that's fixed, I would like to change the fuel filter.
                I drive like a granny since I have a 4door now.
                  with the up to date tune ups and a replaced fuel filter. i dont see much better than 25 but even that is pushing it. u will also need to clean out ur egr system and maybe seafoam the bitch.
                  (129)Transactions and counting
                    What do you think?
                    Turning the EGR and EVAP off won't increase your mileage... they'll actually decrease it a bit. So don't do that.
                    I'm thinking a turbo cam might help you. Less overlap -> less unburned fuel getting sent out the exhaust. You'll lose some power though.
                      a custom cam, and a good tune, and you should be able to hit 26-27mpg
                      unfortunately egr and evap gets eliminted once you use a p06, p28, etc
                      civic or teggys dont use egr
                      another way, would be using a apex or fuel controler and tuning with that, and still keep your egr, dont know how your o2 will react to such a lean mix
                      also, automatic and these goals are a no-no, your best bet is a LX-DX tranny with 22" rims
                      Just do what PR CB7 said.
                        i do mostly highway as well but dont try to get the best milage and i usually get around 24-25mpg
                          right now i filled up 11 gallons and i drive like a grandma going 55 to 60 mph. I have a full tank of gas and i drove 107 miles so far.
                          I drive about sixty miles a day, about 4 gallons.
                          And i still have a fill tank. You should be getting aleast 150 miles by your half point
                            I forgot about wheel size.
                            I know the automatic wagon tranny is geared differently for better mileage... Maybe the manual is the same? Custom gearing + huge tires would help though.
                              It doesn't work that way....
                              Trust me, if it did, I'd be rolling around with 26s and a 80 profile.
                              80 = 185/26/80
                              Below is a thread where I discussed the same thing:
                              http://www.cb7tuner.com/vbb/showthread.php?t=169997
                              MRT
                              sneaky motherfucker
