RPM Gauge going crazy
    hey so i was taking apart my gauge cluster out of my take to put led bulbs in there and since i just put a different steering wheel on my SRS light was showing up so i took it apart and got the light out .... put it back together and now when i am drive my car my rpm gauge sits at like 5g and than when i am driving it goes all the way around.... so i took it back out and put the needle back where it belongs, started my car up and the it went right back where it was sitting at like maybe (10grand) if the gauge would go that high ....
    u guys think maybe the needle got moved when i had it apart and wont work anymore and i gotta buy a new one?
    idk i am lost ............
    Are you sure it's your gauge, and not your ignitor?
    MRT
    sneaky motherfucker
      Perhaps... I'm not very sure what you're describing, but I have a pretty good picture of everything you did that has nothing to do with this problem...
      If you messed with the needle or gauges, you probably threw something off. Chances are, you'll need a new cluster, as fixing a busted one can be a pain. I'm not really sure what your steering wheel or LED additions have to do with the RPM gauge not working properly... or why you messed with that in the first place.
      Another reason that the RPM gauge could go crazy is a failing ignitor.
        well for the fail ignitor is not the problem b/c it worked 1 min and the next it doesn't ..... but from what u said that if it gets messed with it wont work ... so i guess this week going to the junk yard and pulled a cluster ... meh its only 10 bucks ... but live and learn ty guys
          I don't understand a word you just said, but it seems like you're pretty quick to dismiss the ignitor.
