Bought some new spark plugs.
    Bought some new spark plugs NGK V-Power there really good.
    Economical performance and improved ignitability over standard NGK Spark Plugs original equipment manufacturer and racer approved.
    * Lowers ignition system voltage requirements
    * Greater ignitability and performance over conventional spark plugs
    * “Trivalent Metal Plating” has superior anti-corrosion and anti-seizing properties
    * Increased fuel economy and lower emissions
    * Highly durable against electrical and chemical wear
    * Good performance spark plug
    soo... you work for ngk?lol
    v-power is the only type i use in any honda swap period.
    is good that you know this
    Just do what PR CB7 said.
      I just put V power in mine. Better mpgs and higher revs.
      Is V power Iridium?
      MRT
      sneaky motherfucker
        no i dont work for ngk lol i got this from online
          As long as you have quality spark plugs that perform to the level that the engine requires, there's no benefit to "upgrading" to anything fancy.
          I do agree, though... the V-Power plugs have always worked well for me.
            Originally posted by preludebro View Post
            Isn't these spark plug supposed to burn more fuel or something??... Actually any spark plug that's a step up from OEM? Correct me if I'm wrong. but if this is true... why buy higher priced spark plugs up from OEM if your not supplying more fuel...? idk
            O E M
            if your engine performs worse just by changing to v-power, spark plugs should be the least of your worries
              The ECU isn't going to know what spark plug you're running, and as long as your engine is working properly, the plugs recommended by the factory will work efficiently enough to burn the air/fuel mixture completely. The only way the ECU would know you had different plus would be if the stock ignition system wasn't working properly, and the OEM-spec plugs couldn't ignite the mixture well enough (and as PR CB7 said... that's not a plug issue, that's something else that you should be looking at!)
              The ECU would only see a difference if the burn was incomplete, via the o2 sensor readings. Only then would fuel delivery be altered.
              Any spark plug that exceeds factory specifications for a stock or near-stock engine is useless... It's like running higher octane gas in your car when it doesn't need it!
              My H22 takes "better" plugs than an F22 would. I believe it requires platinum plugs. It also requires premium fuel. Because that's what the engine was designed for, it is what I buy. However, if I was running an F22A, I wouldn't be wasting my money on that stuff.
              Oh, I once used Bosch Platinum +4 plugs... because the fucktard at Autozone told me how good they were (this was before I learned to think for myself when it came to my car...) Those "fancy" plugs actually did have a negative effect on my car... it ran like crap, and they fouled quickly. I put in some basic NGK Platinum plugs, and the difference was noticeable.
