What models have a light under the hood?
    I tried finding a difference sticky, instead I found a few very good ones about maintenance procedures
    Anyway, my friend has a 92 LX, with an under hood light. It looks stock, and we can't tell if it works, because the wire snapped.
    My 93 10th AE doesn't have one. Does anyone else?
    MRT
    sneaky motherfucker
    ive never seen an underhood light on any accord. my beretta has one..
    COUPE K24
      After market I would say.
      Make yourself one...with a switch for your own convenience.
      Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
        I've never seen one with a stock light. The only lights I've ever seen have been creations of the car's owner. My friend just wired one up using a spare turn signal light.
          Ive pulled fancy ones out of a car or two at the junk yard and retrofitted it that way as well. Every car I play with has a light under the hood. You can pull the switch too and then install it in the jam(where the hood meets the fender)like it was on the car it was pulled from. Just remember to use some paint(little 10$ bottle from the dealership will do) to paint the hole after you drill out so it doesnt rust.
          Wire that switch into the battery with 12 or 14(use whatever it was already using) gauge wire, a 10 amp fuse and presto! The wires from the switch to the light could be extended(which is what I did) so that they run with the hoses that go to the nozzles for the windshield wiper fluid rather then flopping around in the engine bay. Zip tie the wires to the hoses, snip the extra little bit of zip tie off and viola, nice install looking OEM
          Originally posted by wed3k
          im a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
