oil smoke/smell?
    oil smoke/smell?
    So after running the car for awhile it starts smoking from under the hood. Not to bad just a little bit after it runs for 20mins. It seems to be coming from the bottom of the exhaust manifold in the front of motor. Now it has a bunch of crap(oil dirt) on the head below valve cover and my thoughts are that its oil burning off from the valve cover leaking. Thats going to get replaced this week along with the distributor seal. Question being is there any oil seals behind the exhaust manifold that could be leaking? Thanks
    Are you sure it's not the manifold itself?
    I'd take off the heat shield and degrease your engine to find the leak, instead of just guessing.
    MRT
    sneaky motherfucker
      That was kind of the plan. Is there any sensors on top of the tranny to cover when degreasing/washing the engine? I plan of covering distributor, coil and whatever else needs covered.
        I wouldn't recommend degreasing just yet, I'd continue to diagnose.
        When was the last time general gaskets such as VC gasket, dizzy seal, exhaust mani gasket, etc. have been replaced? Do they appear dried? There shouldn't be oil coming out of the exhaust ports. But it is possible that there is a seep and is sitting on the mani when hot.
        life is good.
          I just hosed the entire thing down. Stopped working a few hours later though
          It was water in the distributor.
          AFAIK there's just engine block under the manifold.
          MRT
          sneaky motherfucker
            I have no clue when the gaskets would have been replaced all i know is it clearly needs v/c and distributor gaskets.
              I would clean the motor and look for a leak. If oil is burning on the exhaust manifold, then oil is leaking onto it.
