hello my friend just bought him a 93 4dr accord with the f22a1 motor. and he found a t3/t4 turbo kit on ebay it is from a company called dna motoring.has any one heard of them and if so are they a good company thanks for the help....
turbo kit
He'll want to be really cautious about eBay products.
Do you have a link?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
If you and your friend have no idea what it takes to turbo a car, then you should do a TON of research before you even buy a single part. Buying a kit is the easy part. Bolting it on is fairly easy as well. Having things set up, and the ECU properly tuned (that's the tricky part) to run things without blowing up... THAT takes a bit of time, money, and a LOT of knowledge to do properly.
But yes... an "ebay" turbo kit is usually going to be cheap crap that won't last very long. If you don't know enough to determine if a kit is good or not, then you really don't know enough to safely turbo a car.
Use caution when running ebay parts. Bottom line.
SSautochrome and ebay brand manifolds whether log type or not, are prone to cracking.
When air is compressed, it heats up-and fast. It needs to be cooled, and correctly. That, proper atmo and bypass, fuel tuning, internal engine condition, tuning, there are so many aspects that are key and need to be paid CLOSE attention to. It's just not as simple as bolting up a $600 kit, sorry. Sure it might work temporarily; but he wants a reliable car too I assume.
homemadeturbo.com is a great resource, the guys there are generally nice. I agree with Mike, you must research, and comprehend all the details in order to be properly educated on the matter. Otherwise all that money and hard work will become wasted.
In the case of the F22Ax, they respond well to boost if built properly. Even stock there are some very impressive ones on "low boost". And, once again- I'll mention TUNING. Very very important. More air=more fuel. And it goes even more beyond just that. Even some DSM parts may be used in conjuction with over the counter parts. Some guys pay someone else 3 grand to do the work. Why do that when you can get educated in the process. Do some research, gain the experience, build and boost, blow it and learn. The only way it'll be solid for you guys in the future. G2IC also has a great noob resource.
OP, how many miles on your buddy's engine? A compression test is one thing, but a full leakdown test is always recommended. Any issues internally will be made even worse when boost is introduced. An engine's essentially a bigass vacuum pump. Keep that in mind as well.
life is good.
