i just installed a short ram intake and now when i barely press the gas it surges up to almost 2k. as in when im backing out of the driveway i dont hit the gas the car just hits the friction point and takes off. it also surges when i shift sometimes. any ideas what could cause this? sri is a relatively easy install so im pretty sure i didnt mess anything up but i could be wrong, thanks
surging rpms
sometimes a cleaning of the throttle body helps as well as adjusting the idle.
Does it only do it when its cold? If it does search "FITV"What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by stlcb92lx View Posti just installed a short ram intake and now when i barely press the gas it surges up to almost 2k. as in when im backing out of the driveway i dont hit the gas the car just hits the friction point and takes off. it also surges when i shift sometimes. any ideas what could cause this? sri is a relatively easy install so im pretty sure i didnt mess anything up but i could be wrong, thanks
What all did you touch? If it wasn't doing it before, and is now, you've messed something up. My guess is a vacuum line somewhere.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
its not an idle issue. it idles fine, ive cleaned my FITV and never had this problem before, it may be the vaccum line that was at the top of the old intake tube at the tb end. i just left it open and then plugged it but the problem was there both times. when i barely tap the gas you can hear it sucking air and it just takes off if i let the clutch out in gear. and when i upshift or downshift at the right time it surges also.
Originally posted by stlcb92lx View Postits not an idle issue. it idles fine, ive cleaned my FITV and never had this problem before, it may be the vaccum line that was at the top of the old intake tube at the tb end. i just left it open and then plugged it but the problem was there both times. when i barely tap the gas you can hear it sucking air and it just takes off if i let the clutch out in gear. and when i upshift or downshift at the right time it surges also.
91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
Neuspeed Super Cup Kit (7/2010)
TAS rear drum-to-disc conversion (6/2010)
Above photo taken - 4/2010
