93 clutch leakage....
    ..i recently changed my clutch and flywheel...and i noticed since then my clutch fluid been leaking ...or should i say disappearing...i checked under the car no puddles of fluid...its been going on for a couple of months..it started out like every 2 days illl top it off..now its every day the resesvior is empty..!!...also my power booster is going ad i have to pump the brakes very morning until it holds..will this affect it in any way...??
    It looks like you have 2 problems.
    Find out where the clutch fluid is going (it's brake fluid)
    If the brake booster is going then you'll have a VERY stiff pedal.
    If you have to pump the brakes then you have air in your lines
    If you pump the pedal to get brakes, but then it still falls, then you need a new master cylinder.
    MRT
    sneaky motherfucker
      The clutch system uses brake fluid, yes, but it is a completely different hydraulic system. It has NOTHING to do with the brake components. If you don't know what you're talking about, please don't spread misinformation.
      The clutch master cylinder is probably leaking. It tends to leak inside the car, so check for dampness on your floor under the pedal. The fluid is corrosive, and eats paint, so if it's leaking inside the car you'll want to thoroughly clean that area before it does serious damage.
      Replace both the master and slave cylinders, and properly bleed the system.
        Also check the slave cylinder on the front of the transmission, The piston seal on mine became very pitted and would leak slowly over a few months. The best way to tell if its leaking here is to get under the car and look for a dark stain down the transmission directly under it.
          OP said clutch AND booster were giving him problems.
          I addressed both problems.
          MRT
          sneaky motherfucker
            Read his whole post
              thanks ill check those spots out .....
                ohh i failed to mention that i had no problems with the clutch fluid leaking until i changed it....so im thinking it wasnt bled properly?...just a thought i might b wrong ...but ill check it out your pointers tommorrow....raining out here in ny
                  You're right. I missed that.
                  I hate when people make a post about one problem and then continue to ask about an unrelated problem in the same thread. Make two fucking threads for two different problems. It's not that hard.
                  I apologize. Your advice is spot-on for the brakes in that case.
                  You shouldn't have to disconnect your hydraulic system to change the clutch. If you did, then you need to re-bleed the system... but that wouldn't account for fluid loss.
                  If you wish to add something after a post, please use the "edit" button. Don't make multiple posts one after another. That will just get your thread deleted.
                    ohhh im sorry...new to this form...ill remember that for the next time i have any questions
