e-brake doesn't work
    my e-brake doesn't work at all could it be the brake drum on the back? or what? I want to know how i can check before taking it to a shop and spending money on something i can do myself
    Ol' Skool FTW!
    If the cable is not broke, you probably need new rear pads. you should be able to do that without spending money at a shop. good luck man!
      you could try tightening the adjusting nut on the end of the brake lever. You just remove the center console around the e-brake handle to access it. Jack the back end of your car up and make sure the wheels spin freely with the brake disengaged. Tighten the nut until you feel a slight resistance when spinning the wheels (e-brake still disengaged). Back off a turn or two so your brakes aren't dragging. Then pull the brake handle and see how it feels. Hope this works for you, it's the best thing to try first.
      http://www.cb7tuner.com/vbb/showthre...=1#post1823428
      My Custom BB6 Dash Swap Thread
        Tighten it while the lever is up one notch. That way, you can let the lever down and have no resistance.
        MRT
        sneaky motherfucker
          koo good looks fellas, ima do that il let u kno how it goes
          Ol' Skool FTW!
            tightening failed, ima have to buy the brake drum, thanx tho
            Ol' Skool FTW!
              Its not your deums its the cables, I had the same problem when I had drums, I say go rear disc swap easy to do. Well thats a good excuse to do it haha. I hope you fix the problem
              NEW CB
              old Darkcloud : 1990 Accord EX MRT
              new
              DARKCLOUD : 90 ACCORD EX MRT
                so if its the cable and i tighten it and it still doesn't work then how do u fix tha problem? and what do u mean rear disc swap? like change the drums and buy disc brakes?
                Ol' Skool FTW!
                  i had the same problem. only one side of my rear brake were working. i found out by jacking up the car from the rear with the ebrake up and i spun the tire with no resistence at all lol. brake line was snapped thats y.
                  Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
                  My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
                  Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
                    ooohh shit!, and to a complete noob at fixing cars can u tell me how u fixed that problem did u do it urself or took it to a shop?
                    Ol' Skool FTW!
