So my car will not start up. I was driving home last night and it was running great. Got home then 30 min later I tried starting it to run to the store. SURPRISE...car not start. Great. It's done this in the past but I thought I fixed it with a new battery, spark plugs, and distributor cap. But I guess not. Now I need some help figuring what it is now. My plug wires look in good shape so I don't think it's that. Alternator? Distributor? Idk. Need help guys. Thanks.
Car won't start after running fine.
Pull your valve cover off and check your timing belt. Or pull your distributor cap off and turn the motor over to see if the rotor spins. Timing belts are more prone to breaking during starts and stops.
If the belt is not broke, check to see if you are getting spark (remove plug, ground, turn motor over). If no spark, you have an ignition problem. Coil or distributor / ignition control module.
If you get spark, check to see if you are getting fuel. Listen for fuel pump priming when ignition is turned on. If you hear the pump, check to see if you are getting pressure at the rail.
It can only be a fuel or spark problem if the air flow is not obstructed. You just need to narrow it down to one or the other and work from there.Last edited by FAK_LAF; 02-18-2011, 10:18 PM.
I think pulling the valve cover is a little bit extreme. If you suspect a timing belt I'd pull the distributor cap and see if the rotor is spinning.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
