How exactly do batteries work?
    I thought there were:
    1. Lead cells with acid surrounding them
    OR
    2. Lead cells with acid inside them and water outside to cool it.
    http://www.cb7tuner.com/vbb/showthread.php?t=172875
    There's quite a bit of fluid leaking out of the missing side of the battery.
    Is it water or sulfuric acid? Or a mix? I poured baking soda on the leak and got an appropriate reaction. How long till the battery gives out?
    MRT
    sneaky motherfucker
    if the battery is leaking its bad and should be replaced. any acid that comes out can chemical burn you,cause corrosion to anything that it touches in a car,eat paint,etc. most new batterys are self contained and you cant put anything in them. they also make gel batteries and glass mat.
      has 'plates' and acid reacts with the 2 dissimilar types of metals in the 'plates' and it creates electricity.
      COUPE K24
        Just checked - Yep Google still works.
        http://www.vonwentzel.net/Battery/00.Glossary/
        http://www.howstuffworks.com/battery.htm/printable
        How long will your battery last? Not sure.
        If it's leaking it needs replacing - So replace it.
        My 5.7 LS1 Holden Ute
