Oil Leak
    Oil Leak
    Your best guesses please.
    I thought it might be the inner distributor seal or one of those temperature sensors.
    MRT
    sneaky motherfucker
    mine leaks in the exact same spot cant figue it out, the distributor seal is like 99cents from honda i got it just never put it on
      O ring from napa is $.63 and will fix your leak.
      H22a $1000
      Msd 6al $ 200
      Fuel cell $ 200
      Carbs $ 125
      Manifold $200
      Lines etc $ 100
      Header $ 400
      GSR seats$ 100
      Being the first and only streetable dd cb7 w 4 carbs...
      PRICELESS!!!
      Pics.. http://m891.photobucket.com/albums/alexiadanza/
        So this is the inner seal?
        MRT
        sneaky motherfucker
          yea its the inner distributor seal...its a common leak spot on the f series
            The O-ring seal cost very cheap the inner distributor seal cost a bit more.
            To determine which seal it is just take off the cap and see if there's oil on the inside of the dizzy, if there's none then it's the O-ring seal.
            Yes my name is Dang, Don't use in vain
            1992 Honda Accord EX (Coupe/Bordeaux/Auto)
            1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
            2008 Honda Accord EXL (Coupe/SanMarino/6spd)
              the leak in the first pic looke like the o-ring seal, a very easy replacement. mark the distributor timing across the top ear of the dizzy with a pencil or screwdriver. remove three bolts, and pull the dizzy off, remove old seal and replace.
              1990 accord Honda-Challenge, H22 powered
              newer race video,older race videos
              1991 accord parked, parts and back up shell
              1993 accord acquired 6-11-16
                I've got the new seal. I'll be replacing it shortly.
                MRT
                sneaky motherfucker
                  This helped a lot. I cleaned the area off with TB cleaner and it looks like the leak is fixed.
                  Next question:
                  Can I keep using TB cleaner, or should I use brake cleaner to get the rest of the oil off?
                  The bad: I found out my spark plugs are leaking. A lot.
                  MRT
                  sneaky motherfucker
                    Yea, that's not your spark plugs leaking, it's your tube seals. Buy a v/c gasket kit. Buy a manual (haynes or chiltons) rent or buy a torque wrench. There are upper and lower tube seals, change both. The lowers are under the cam caps, this is where the torque wrench comes in. Also not a bad time to lash your valves while you have the vc off. I run .010/.012, but specs are on the hood and in the book. Also a good time to change plugs. .... Aahh... general maintenance.
                    H22a $1000
                    Msd 6al $ 200
                    Fuel cell $ 200
                    Carbs $ 125
                    Manifold $200
                    Lines etc $ 100
                    Header $ 400
                    GSR seats$ 100
                    PRICELESS!!!
                      I was planning on having the dealership adjust my valves in the spring....
                      I guess I'll have to make a decision. Do it all myself, or pay the ship big bucks.
                      MRT
                      sneaky motherfucker
                        It's not that hard, just take your time, be careful, and use the torque wrench!! First time I did it took a few hours. Now I can lash all the valves in less than 30 minutes. Just have patience, preperation, and proper tools. Forget the dealer, there are plenty of qualified mechanics that won't rape you like the dealer.
                        H22a $1000
                        Msd 6al $ 200
                        Fuel cell $ 200
                        Carbs $ 125
                        Manifold $200
                        Lines etc $ 100
                        Header $ 400
                        GSR seats$ 100
                        PRICELESS!!!
