my right balljoint broke today i got a new one i just need to know the easiest way to get the old one out
broken balljoint
There are videos showing how to replace the ball joints in the read here first section. Broken ball joint removal is one of them.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
For installation I used a ball peen hammer. Seriously, go watch those videos. Tells you EXACTLY what to do.MRT
If u go the autozone route you'll probably have to get the adapter set also, cause the cups and shit wont fit unless u do, thats why ppl are smashing them back in instead of using the press. Use old 13/16 deep socket to pound it out with a 3lb hammer after u remove the snap ring overwise you'll be pounding all day. Clean it up, get some multi purpose lube and use a breaker bar with your press adapter set and she'll go in smooth and straight and wont fuck the back of your bj up or go in crooked.
Adapter set
http://www.autozone.com/autozone/acc...er=948074_0_0_Last edited by rayray91; 01-26-2011, 01:41 PM.
Originally posted by rayray91 View PostIf u go the autozone route you'll probably have to get the adapter set also, cause the cups and shit wont fit unless u do, thats why ppl are smashing them back in instead of using the press. Use old 13/16 deep socket to pound it out with a 3lb hammer after u remove the snap ring overwise you'll be pounding all day. Clean it up, get some multi purpose lube and use a breaker bar with your press adapter set and she'll go in smooth and straight and wont fuck the back of your bj up or go in crooked.
Adapter set
Getting the ball joint out was the hardest part. After that, it took maybe 2 minutes of pounding before it seated completely.
For removal "the right way" I'd go to harbor freight. They sell a tool (can't remember the name) that removes the ball joints with ease! And it's NOT a pickle fork. Don't ever use those.
IMO getting suspension parts from a junkyard is like buying used oil. Unless it's just a metal part, like a control arm.
Lastly; Get your ball joints from the Honda dealership. Always replace in pairs.MRT
The tool you need is a ball joint press. I rented mine from oriellys for 100 bucks but you get every penny back if you return it within two days. Makes the job really easy with the right tools. As for ball joints just hammer them back in with a hammer and a flat piece of 2x4. Best way to press out the ball joint is to take the entire arm out and put it in a vice when using the press.
