im missing third gear and i was wondering can just the gear be replaced or does the whole transmission have to the rest of the gears work fine 3rd just grinds
Missing 3rd gear
Your syncronizers are shot. You'll need to either replace the transmission, or rebuild it. If the gears themselves have been damaged, they may need to be replaced in a rebuild as well.
You could try changing the fluid... use GM Synchromesh Friction Modified fluid. It won't fix any damage that has already been done, but it may ease the grinding for a bit. It'll buy you some time, at least. Don't do a flush... just drain and refill. It'll take just under 2 quarts.
automatics are far more easy to rebuild
manuals you must have a good quality standing press first. None of that harbor freight shit, I've seen 2-3 of them split the plates used to hold the part you are applying tons of pressure too...ever seen a metal plate with a 1.5-2 ton jack pressing it shatter? Not cool...avoid harbor freight presses
Manuals have fewer parts but EVERYHING is pressed on and that makes it a bitch.
rebuild kits (all I inclusive) are around $200...the press is expensive though____
Originally posted by deevergote View PostYour syncronizers are shot. You'll need to either replace the transmission, or rebuild it. If the gears themselves have been damaged, they may need to be replaced in a rebuild as well.
You could try changing the fluid... use GM Synchromesh Friction Modified fluid. It won't fix any damage that has already been done, but it may ease the grinding for a bit. It'll buy you some time, at least. Don't do a flush... just drain and refill. It'll take just under 2 quarts.wat?
Originally posted by angel4b View PostI have this same 3rd gear griding problem too! My mechanic just said to slow down a bit (stop accelerating) before shifting to 3rd, and this seems to eliminate the griding noise. How long to I have before I have to fix this for real?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by angel4b View PostThanks for the advice. 3rd gear has been grinding since before i bought this car from my boyfriend. Its a good thing i try to avoid driving in the winter! I'll see about starting that project in the spring/summer when its actually possible to fix your car outside in cheeseland.wat?
Originally posted by C91BLX7 View PostClutch in, shift to neutral clutch out, then shift to 3rdMRT
