Hey guys.
I am in dire need of your knowledge. So the 93 Accord I have with a h22a motor, failed to start in the cold morning in Southern California. So I decided to change out the spark plugs, as I took them out the spark plugs had no gasoline scent to them. So I thought "dang, fuel problem" but I changed the plugs anyways and I got the car started after a few attempts, but the car ran pretty sputtery, but my dad took it out on the freeway to try to free some gunk up. I had occasionally put fuel injector cleaner in, with 89 pump. But when we got the car back home, we let it cool down, then tried to start it, but it wouldn't start up right away, it took a few tries. Then I decided "hmm maybe its the engine coolant temperature sensor" so I went to the local Pep Boys and bought myself a new temp sensor, (put the new one on, but overtightened it and it broke) so back to Pep Boys to exchange. I put it on, filled up the coolant again, put the positive battery terminal back on. And started it, it cranked for a second then it started. I was like "YES"
The car starts perfectly when the motor is hot. But when it is fully cold again, it fails. What could be the issue? Maybe its my Positive battery terminal? because the terminal is SLIGHTLY loose, also because it is old. Should I have to do anything with fuel pump? fuel filter? fuel main relay? crank sensor? As we are all low on budget, and it is always smarter to go from the item in which costs the less money. Any help appreciated. I am however sorry if this post has already been answered by another person's question, I could not find it in the Search tab. Thanks.
EDIT: I do not think its the fuel pump, because when I checked the fuel line that was going to the injectors, the line had pressure in it. So maybe not the fuel pump. Maybe the injectors? Or fuel filter dirty?
