Does anyone know what this is?
This topic is closed.
    hey guys so i came across this thing and I have no idea what this is. I heard its a sensor but what does it do? I looked everywhere in the web.
    MY MRT
    http://www.cb7tuner.com/vbb/showthread.php?t=178936
    shift solenoids
    COUPE K24
      Transmission solenoids
      MRT
        Correct. they also tend to stick and clog. So if you start getting any shifting issues unbolt them and clean the screens.
          Not to state what I am sure is obvious, but since some are less mechanically minded and for someone that may look and wonder about his in the future.....i think its worth specifying "AUTOMATIC" transmission
          Now, I am making this assumption based on the prior 2 posts ( as I didn't know what this part is either before this thread ) ...if I am wrong, just slap me, I do make the occasional mistake!
          Bought from Darkcloud
          http://wheelflip.com/r/DrAkE
            Yes you are correct those are automatic transmission shift solenoids. Thank you for bringing that up. Now all typed out like that will pull this post up if someone searches for it.
              What do you clean them with?
              MRT
              sneaky motherfucker
                im sure brake cleaner or parts cleaner would work fine.
                  That works well, then spray all the cleaner out with your air hose
                    Thanks bros for your help . Yea it has been happening to me a few times the car would not shift properly. Its automatic btw. I got a new TSU and now I just need to clean theses. Thanks alot again
                    MY MRT
