short ram intake advice.
    alright so i got a 92 EX STOCK, i'm trying to put an intake into my ride but idk what kind, i would like some helpp on which kind and also if a short ram intake is better than a regular cold air intake? help please.
    <-- LMFAO
    this is the one i got but crome
      and how' s that working for your car?? is it the same filter or did you put a better one??
      <-- LMFAO
        As far as which one is better I can only tell you what each one is supposed to do.
        Short Ram- Supposed to provide more torque and upfront power.
        Cold Air- Supposed to give you more power in the higher RPMs range on the back end. That is just what I have read. I think there is a thread some where here.
        I got board one day and got this set up
        I started off first with the basic intake. That had came straight out from the IM. with the filter it ran me maybe $55 from autozone. $20 for the filter and $35 for the intake. Later i added a 60 degree elbow and a 90 degree elbow after I relocated the battery. The set up has been pretty good so far.
        IridiumCore
        HCK-The Beginning
        Your drunk she doesn't look that good.
          Use the "search" button on top. There's been plenty of threads on this.
            the short ram is working good for me i you can hear mine sucking in alot of air cause i have a stock exhaust so its all you can hear
              try this out , cut your stock air tube, and buy a good cone filter and a clamp.then remove the old filter housing.IMO just as good as a cheap no name intake pipe.keep the blow by valve( the pipe running to the intake tube close to the TB ) good luck and hope you give this a shot.
                A pipe is a pipe. Get a cheap pipe off of ebay, and put a high quality filter on it, such as AEM or K&N. Don't use a cheap filter, as they can let dust and dirt into the engine, causing damage.
                  that sounds like a plan i might try this
                  Originally posted by Gummiegorilla
                  Damn CBs are like a Rubix Cube sometimes !!!!
                    dont short rams kill ur mpg's due to the fact that its sucking up nothing but hot air from the engine bay??
                      If anything, they help a little tiny bit (<1mpg) by lowering the resistance of the air being sucked in compared to the stock intake.
                        Is this a Short Ram or a cold air intake?
                        MRT
                        sneaky motherfucker
                          My guess is he is trying to make a cai but I don't think much air gets there
                            Short Ram.
                            From what I have seen, cold air intakes sit down in the area between the inner fender and bumper. Short Rams are anywhere in the engine bay.
                              short ram.. a true cold air is tucked below in the fender well...if u get a cold air just make sure u get a bypass valve so u dont suck up any water..
