Hey guys,
I was curious about possibly upgrading my master cylinder. I am purchasing a wilwood big brake kit (front and rear) for my car, it has 4 piston calipers, and also a larger rear piston in the caliper.
Is there a larger master cylinder you would recommend for me? If so from which vehicle?
And do you recommend buying a new 4040 prop valve, or should the used one be sufficient?
p.s.: I'm already aware that the majority of the braking is done in the front of our car, I want to have the rear big brake kit as well for appearance and performance.
