Upgrading Master Cylinder/4040 Prop Valve
    Hey guys,
    I was curious about possibly upgrading my master cylinder. I am purchasing a wilwood big brake kit (front and rear) for my car, it has 4 piston calipers, and also a larger rear piston in the caliper.
    Is there a larger master cylinder you would recommend for me? If so from which vehicle?
    And do you recommend buying a new 4040 prop valve, or should the used one be sufficient?
    p.s.: I'm already aware that the majority of the braking is done in the front of our car, I want to have the rear big brake kit as well for appearance and performance.
    From what I've read the ABS M/C has more stopping power than it's sibling.
    MRT
    sneaky motherfucker
      Okay, nice. Do you recall if the acura mc holds more fluid? Id definitely need more fluid to compensate
        i think u can use a master cylinder for a bb1-4 prelude vtec mc. its for the larger brakes. im considering using one. as ive upgraded to those calipers and upgraded the prop valve.
        (129)Transactions and counting
          Alright, I wish it was summer here, its like -37 outside with windchill
            If the kit is sized appropriately your master cylinder wont need changing. If you insist on upgrading, a 1" BORE M/C for an Accord is normally more than enough. You can get one over the counter from any parts store.
