ths problem just started today. i was being stupid and jumped in the fast lane and took it up to about 110. at that point, i heard a rumble/vibration noise from in front of me. my guess is that has something to do with my crappy blown coils or the slight rust on the springs or maybe a wheel bearing. if you could let me know that would be awesome
high speed rumble
Coils don't blow, shocks do... and honestly, if you have blown shocks and were going 110, that was most likely the sound of your tires bouncing off the ground over every little bump, because that's what they do with blown shocks. Good thing you didn't need to slam on the brakes, because you wouldn't have stopped.
Other possibilities are wheel bearings, imbalanced tires, or improperly worn tires.
Originally posted by deevergote View PostCoils don't blow, shocks do... and honestly, if you have blown shocks and were going 110, that was most likely the sound of your tires bouncing off the ground over every little bump, because that's what they do with blown shocks. Good thing you didn't need to slam on the brakes, because you wouldn't have stopped.
Other possibilities are wheel bearings, imbalanced tires, or improperly worn tires.Originally posted by rickyduckworththat's pretty interesting. when i get that bored i just watch porn and go to sleep
Stock shocks? Cheap-shit $50 ebay coilovers (which also don't "blow" by the way.)
If that's what you're running, I wouldn't even risk driving that car until it's replaceed with safe components. Why the hell are you taking your car to 110mph with bad brakes and shitty suspension components? All you need is one dumbass to not look in his blind spot, cut you off, and you'll be upside down and on fire in a ditch before you know it!
deev, they sag real low by which i meant, like they suck ass. the brakes work fine but once in a blue moon, they decide to depress more than usual. om going to be picking up i believe tien s tech lowering springs. i want the Form&Function coilovers but theyre around 800 bucksOriginally posted by rickyduckworththat's pretty interesting. when i get that bored i just watch porn and go to sleep
I'd say wheel bearing. Get a mechanics stethoscope or take it to a shop. They checked mine for free.
Wheel bearings are like the lotto. I drove on mine for 4k (I thought it was the muffler), but the mechanic said he had some people barely make it the 2 miles to his shop.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Only if it's REALLY bad. Mine didn't have any play at all.
I just did a 92 front end. Got it all put back together and noticed wheel shake on front drivers side. Wheel bearing according to the alignment folks.MRT
