im guessing the heater core is clogged, i hope not since its in the dash somewhere..... any insight on anything else that could cause this, car runs at normal temp's.. heater kinda works but not like it should.. anyone changed a heater core? was it hard?
heater doesnt work, halp!
check your thermostat first, second your heater control valve cable to make sure its opening the valve.Header Whorage and Official Part out sale.
Official Garage Sale Thread
http://jdmconcepts.com/ Head porting specialist..
how do I manipulate the cable?
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
Originally posted by UnderPaidSlave View Postanyone changed a heater core? was it hard?MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Did you put any "stop leak" crap in your radiator? If so, then that would be what clogged your heater core (if that's the issue.) Very often, that's the cause of a clogged heater core. Another cause would be extended use of unpurified tap water as coolant (deposits build up and cause clogs... straight water should never be run as coolant, and only filtered water should ever be used if mixed with a concentrated antifreeze coolant.)
Originally posted by deevergote View PostDid you put any "stop leak" crap in your radiator? If so, then that would be what clogged your heater core (if that's the issue.) Very often, that's the cause of a clogged heater core. Another cause would be extended use of unpurified tap water as coolant (deposits build up and cause clogs... straight water should never be run as coolant, and only filtered water should ever be used if mixed with a concentrated antifreeze coolant.)
do the fans come on when you turn the knob ? if so , i'd say the heater core is shot . i have seen cases were the core was bad but not leaking.( stopped up ) . if its stopped up it will run hot because its not flowing properly. drain and reflush the system .
As stated above, check the heater control valve, I think it should be turned toward the firewall.Last edited by alan lx; 01-03-2011, 05:13 PM.
Originally posted by stretch JDM View Postdo the fans come on when you turn the knob ? if so , i'd say the heater core is shot . i have seen cases were the core was bad but not leaking.( stopped up ) . if its stopped up it will run hot because its not flowing properly. drain and reflush the system .
im having the same problem exept mine blows regular air, not warm not hot.. they told me it could be a fuse "12"AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
Originally posted by UnderPaidSlave View PostSo, my headlight lens was broken sometime lastnight, how the hell do I remove the headlight housing?AT WEST COAST MEET
