heater doesnt work, halp!
    im guessing the heater core is clogged, i hope not since its in the dash somewhere..... any insight on anything else that could cause this, car runs at normal temp's.. heater kinda works but not like it should.. anyone changed a heater core? was it hard?
    check your thermostat first, second your heater control valve cable to make sure its opening the valve.
    Header Whorage and Official Part out sale.
    Official Garage Sale Thread
    http://jdmconcepts.com/ Head porting specialist..
      how do I manipulate the cable?
      Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
      New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
      2000 EX Coupe - Joe -
      www.AccordWagonClub.com
      My Facebook Site - ACCORDOBSESSION
        I know the thermostat is good, guess I figure out the control valve thing..
          I've changed a heater core on a 94 Cutlass, yesterday I completely rebuilt a front end for a 92 Accord. Guess which I'd rather do again? (Hint: Accord)
          MRT
          sneaky motherfucker
            Did you put any "stop leak" crap in your radiator? If so, then that would be what clogged your heater core (if that's the issue.) Very often, that's the cause of a clogged heater core. Another cause would be extended use of unpurified tap water as coolant (deposits build up and cause clogs... straight water should never be run as coolant, and only filtered water should ever be used if mixed with a concentrated antifreeze coolant.)
              the previous owner users tap water I think, I used some this summer when it was low, but I flushed it out in September "atleaste I tried" hswap anyone haha
                do the fans come on when you turn the knob ? if so , i'd say the heater core is shot . i have seen cases were the core was bad but not leaking.( stopped up ) . if its stopped up it will run hot because its not flowing properly. drain and reflush the system .
                  As stated above, check the heater control valve, I think it should be turned toward the firewall.
                  http://www.cb7tuner.com/vbb/showthread.php?t=178069
                    are you talking about the fans that blow the hot air? yeah. or cool air i guess.. um whats the best way to flush out your coolant system?
                      you can buy a flush kit from most part stores. then drain the radiator , it has a plug on the bottom .
                        Don't forget to try swapping out your main control unit on your dash with all the temperature knobs AC etc, that ended up being my issue. the board that controlled whether or not to send hot air was fried
                          im having the same problem exept mine blows regular air, not warm not hot.. they told me it could be a fuse "12"
                          AT WEST COAST MEET
                          cb7rush: who has the tongs?
                          JDMxDB8: i got a thong on...
                          to get to see more of my cb click the link below.
                          http://www.cb7tuner.com/vbb/showthread.php?t=130922
                            So, my headlight lens was broken sometime lastnight, how the hell do I remove the headlight housing?
                              if you were to create a new thread for yourself you would get a lot of more replies, but to answer your question is easier to get another headlight than changing your lense....
                              AT WEST COAST MEET
