Good morning cb7 and happy new year to all! I'm having a problem in the moring starting my car, it starts, but it starts to gag and eventally gets going, it feels like a fuel problem , possibly a sensor i dont know and dont want to go a pay a mechanic? Once the car goes its rides great, again only in morning or a long period of time when it sits. Has this happen to anyone else? please help. am i missing something? car is tuned upped and well maintained 270.000!
Hard starts only in mornings?
how long ago did you change your fuel filter? could also be the battery is old.AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
Originally posted by iwork4mycb7 View Posthow long ago did you change your fuel filter? could also be the battery is old.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Old batteries tend to retain low cold cranking amperes (CCA). If I remember correctly, Honda Accords should be fine with 550 CCA. Low CCA will result in a situation as you described, though is not the only possibility. Remove the battery from your car and have it tested, they will run a test to determine the CCA available. They will give you a pass or fail result unless you tell them beforehand that you want to know how many CCA your battery has. If the tester does not display that info, ask them what is the fail criteria, in amperes.1997 Honda Accord EX-V6:
C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
MPZA - Electronically controlled 4-speed automatic, 1 reverse
~170 cu. in. / ~170 ft. lbs. / ~170 whp
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
the battery is a die hard 2 yrs old, and did the fuel fillter 6 months ago, i saw one of the cells getting low during the summer and added some water to it? i dont think that would hurt it? I also have an electric remote car starter, but dont use it to much . its seems to be makin it worst in the morning.
What effect filling the cell had really depends on what you put in it: what kind of water did you put in it? Tap, spring, distilled, triple-distilled, de-ionized, de-ionized micropore filtered, HPLC grade, reagent grade, etc.
I also don't believe the age of an electrical component (especially the battery) has anything to do with its ability to function properly, take it out and test it.
From all my years of experience, I have learned to just go ahead and pull the battery and alternator to have them tested out of the car anytime I suspect an issue with my charging system, it's just the prudent thing to do.1997 Honda Accord EX-V6:
I had the Same problem this morning after my car sat for 4 days it did not want to start and when it did it was rough. Doesint the FITV valve have some thing to do with the start up correct me if I'm wrong can't you adjust it and it will stop doing that. I'm going to check mine when I get home and if it works I will let you know.
It's the battery.
I had a 1000 cranking amp battery last winter and it fired up on one key turn.
now I have a 550 cranking amp battery and it takes a couple of seconds before it'll fire up.
Originally posted by James Matteu View PostWhat effect filling the cell had really depends on what you put in it: what kind of water did you put in it? Tap, spring, distilled, triple-distilled, de-ionized, de-ionized micropore filtered, HPLC grade, reagent grade, etc.
clean your IACV...something that everyone should do at least once a yearWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by joker1999Mine kinda does the same thin only when its been sitting overnight its hard to start i have to pump the gas a couple time when cranking to get started and when does start it has the erratic idle where the tach goes up and down. But when its warmed up it runs and idle fine tested alt and battery both passed
