Eliminate ABS?
    Eliminate ABS?
    Is it possible to eliminate this abs thing? abs has never worked right also my intake pipe rubs against the side of it and actually made a hole at one point. If not is there a specific intake made for our cars with abs?
    *note the arrow
    eh, you can. but i here its not worth it. there is a switch or something located in the back you can unhook it and just bend some pipes out of the way. i wouldnt recommend it tho.
    Accord SE
    93se
    Members Ride
    Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
    Sold to: sulimed, BurtonRiderT6, tishock
      Can't believe I'm wasting time to tell you to search the diy section for "abs removal"...
      My Member's Ride Thread
        yea man i would maybe try and fix it cause without it can be alittle sketchey
          Tada! It was right on top too. I didn't even have to enter the forum to find it!
          http://www.cb7tuner.com/vbb/showthread.php?t=38326
          MRT
          sneaky motherfucker
