01 Accord V6 Brakes on CB7?
    Hello,
    I am curious if I grab the whole brake assembly off the 01 Accord, will they work with my CB7? I just found a 01 V6 Accord for parts and I am looking to jump on this opportunity. What about the CV joints? ROH FTW!
    Originally posted by opiateofsorrow View Post
    Hello,
    complete spindle off the 01 Accord will bolt in and give you the ROH AND 5 lug conversion at the same time. the cv axle ends are the same so ne need to change BUT you will have to redo the alignment when done. I used the 2001 Acura TL front spindles on y 90 LX coupe and took a total of 2 hours to swap it over.
      Holy hell! hello 5 bolt and ROH conversion! Thanks man
        Does anyone know of a decent write up on how to remove the spindles? I'm still novice with terminology about what the spindle is, what I'll need for the conversion etc. If someone knows of a write up or can help me with some pictures I'd be super appreciative. P.S. I've been trying to use my search engine on here for a long time but it keeps going to a blank screen
          butttt....
          use google to search the forum.... type in your search term followed by "site:cb7tuner.com" (don't use those quotation marks)
          it works a lot better than the search function here.
          92ex CB7<-SOLD 93ex CB9shiftingshift73C10
            Originally posted by mtnbikaah View Post
            butttt....
            better yet, look at my posts in the past and you will find the thread where i learned to to do the conversion, the thread is originally from member named "dab916"
              Awesommme, thanks so much guys. I will have a look. And I didn't know that about google!
                before i forget again, using this procedure u can't use 15" rims, only 16" and up because the 15's hit the caliper. i know this because i have a set of 15" rims that i can't use because of this fact
                  I can imagine how you felt once you found that out the hard way...
                  MRT
                  sneaky motherfucker
                    any specs on those 2001-spec setups from the Acura and Accord V6?
                      talk about the hard way, the car was on the lift !!!!!!!!!!!!
                      me and 90LXKing had to do some running around FAST
                        i used
                        2002 Acura TL front spindles from the j/y that came with rotors/calipers but reused my accord calipers as the fit with no problem.
                        rear was
                        99-01 Crv drums
                        99-01 prelude hubs
                          That is incorrect. It depends on the 15" wheel. 01 accord V6 brakes are 11" just like CB accord wagon brakes. All of these cars come standard with 15" wheels!
