hi im new on here and i have a question bout my cb7 but its auto but every time the car switches gears it have a kick like someone kicking you in the back or hitting you and this car jux came from my stepfathers friends shop but i dont really trust him but my stepfather says he have a degree but i dont think thats right its been fix by him for 7-8 yrs and never got iit right but this time it runs but with that problem its a ex 93 sedan all i put in there is a intake but i dont think thats y but if you can help tell me wat the problem is then its much appreciated.
93 auto cb7 gear kick
Are you saying the trans shifts hard?If so check mounts and also the tranny fluid.
02 Crv
Hard shifting is a sign of a strong transmission, and our transmissions are known for shifting fairly hard (it has been a source of criticism in the past.)
However, as the mounts wear out, that hard shift is definitely more pronounced. As the fluid gets old, the transmission may also not function as it should. Fluid should be changed every 15-30k miles, depending on how hard the car is driven. People usually keep up with the motor oil, but very few people realize that transmission maintenance is just as important!
Use Honda ATF only. Don't use anything else, even if it says it's good for your transmission.
Originally posted by deevergote View PostHard shifting is a sign of a strong transmission, and our transmissions are known for shifting fairly hard (it has been a source of criticism in the past.)
I've heard from multiple people that if you let fluid that should be regularly changed sit for too long you're better off leaving it. If you change it you're essentially gambling that the component may fail. Case in point: I changed my original brake fluid and had to replace my master cylinder. Fortunately the only fluid I haven't changed yet is my PS fluid.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by wallofchina View Postso should i change the tranny fluid?MRT
thanx and i was reading thread about tcu do i need to worry bout that cuz when i drive normal 1st gear switches 2,500rpm but when it switches to 2nd it switches on 3000rpm any answers?
my car has this plastic smell or some kinda smell to it and it wont go away would that be the smell that my tranny fluid is bad?
should i flush my tranny or keep like that and jux change fluid cuz ive heard some cars dont run right after a flush my question is, is a flush good for 93 accord ex auto?
Originally posted by wallofchinamy car has this plastic smell or some kinda smell to it and it wont go away would that be the smell that my tranny fluid is bad?
02 Crv
Originally posted by wallofchina View Postthanx and i was reading thread about tcu do i need to worry bout that cuz when i drive normal 1st gear switches 2,500rpm but when it switches to 2nd it switches on 3000rpm any answers?
Originally posted by wallofchinashould i flush my tranny or keep like that and jux change fluid cuz ive heard some cars dont run right after a flush my question is, is a flush good for 93 accord ex auto?MRT
Originally posted by wallofchina View Posto ok guys thinks for the help but man its a blizzard out cant do nothing til i get to a dry place but work is all cuaght up on me to..MRT
