Annoying beeping sound
    Anytime my driver side door is open there is this really annoying beeping sound, as if I had left my keys in the car or something.
    Why does it always do this?
    It hasn't been a problem until now. I am trying to install my radio and new door speakers, so the door is open a lot.
    Thanks
    _C'est La Vie, C'est La Mort_
    it's probably something to do with the ignition. Mine does this sometimes, but not consistently. What i do to fix it is put my key in the ignition again and pull the key out again.... I feel something "click" inside the ignition.
    I wonder if there is a way to "lubricate" the ignition????? that might fix your problem.....
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      My 90 does this sometimes, no need to put the key in again, just give the steering wheel a whack, or rap your finger directly on the ignition switch.
        Is there a fuse I can pull to just make it stop?
          I do the same thing, sometimes many times in a row
          There is a speaker up inside the dashboard you can take out. Idk what it looks like on our cars though. I've only seen it done to a few BMW's
          MRT
          sneaky motherfucker
