Fuel pressure gauge on the rail
    Ok I've searched and cannot come up with the answer I seek. I want to put a fuel pressure gauge on a factory rail.
    The reason for this is that I have just replaced the fuel pump after is died, and want to make sure the one i replaced it with is working properly.
    From what I can figure by looking at the haynes there is a bolt on the drivers side of the fuel rail, I believe thats where it goes. I just want to make sure before I get started and find out I'm wrong or have the wrong parts.
    Can't help directly, but from what I've learned Haynes isn't your best bet. Get a Chilton or a Helms manual.
    Chilton: http://cb7tuner.com/vbb/showthread.php?t=147239
    Google Helms
    MRT
    sneaky motherfucker
      Google Helms
      I only used the manual to get an idea of where I might need to put it.
      I was trying to figure something out before I asked on here. I doubt, but could be wrong, that chilton is going to tell me where to install and aftermarket piece.
        The bolt you see on the rail is for relieving fuel pressure when servicing the fuel system and you cannot install a fuel pressure gauge there.
        If you want one you can install the gauge on the fuel filter housing on the firewall. Some companys make a kit ( b&m makes one for sure as I have it )
        that replaces the banjo bolt on you feed line to the rail and it has a new bolt with crush washers that let you mount your gauge onto the top of the bolt.
        The B&M kit says Honda and Acura cars but it will work. Came with everything you need and was around $40.00 I think?
          I had to make my own pressure gauge to test my pump, and I did indeed use the driver side port you mentioned.
          I bought a machine screw (can't remember the size I think it was 12mm by 22?) and a nut to fit. I drilled through the center of the bolt and cut the head off. Attached a hose with a pressure gauge to the bolt with a hose clamp. Ran the nut up the bolt and used some Teflon tape to make sure the bolt would seal.
          Use a pair of channel locks to get the bolt as far as needed and use the nut to tighten it down.
          Test your pressure.
          Click on the Death's Head Moth for MRT
          PSN: Sick6sect
          CB7Tuner Map
            Test your pressure.
            Sick, that just might be crazy enough and cheap enough to work, thank you. I will although check out the B&M kit to try and mount one as a permanent fixture. Thank you all for your assistance in this matter. One more issue fixed with the help of others.
              12mm x 1.25pitch......... I remembered.
              PSN: Sick6sect
              CB7Tuner Map
                Longer bolt would be needed for the home made gauge correct?
                  Around 2"-3" should be fine.
                  PSN: Sick6sect
                  CB7Tuner Map
                    I forgot to mention, grinding the threads smooth (off) where you plan on attaching the hose or else air will escape and you will not get a correct reading.
                    PSN: Sick6sect
                    CB7Tuner Map
