my car idles while i brake..
    it only idles wen i brake not wen i accelerate does anyone know wats the cause of this?
    huh?
    Rush
    Originally posted by Darkcloud
    Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
    Originally posted by bmxicansd
    so you got a boombox, sunglasses and rosettta stone?
      Cars usually idle when you're not pressing the accelerator.
        could we get some more information? automatic or manual?
        92ex CB7<-SOLD 93ex CB9shiftingshift73C10
          well when you dont give it gas it will drop meaning the rpms...But please more info
          Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
          MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
            ok its automatic...wen im in park the rpm is normal but say i keep pressing the break repeatedly its start idleing high...like up to 2500rpm but if i let the break go it stops n it goes back to normal
              possible vacuum leak and idk what else..
              Rush
                Sounds like a vaccum leak.
                Call me Travis.
                2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
                1992 Accord LX ~ "Smoothie"
                1991 CRX Si ~ Hellion
                1989 GMC S15 ~ Oldie
                  When the car is cold it has a higher idle to help heat it up. Once its reached it goal it should fall back to the normal idle.
                  MRT
                  sneaky motherfucker
                    do you know were i should start looking first for the leaks
                      The brake booster is vacuum assisted. Start with the vacuum lines going to the booster.
                        Sounds like the booster itself may be leaking.....if the booster vacuum line was bad it would idle high all the time, not just when brakes are pressed. I don't know what the internals of the booster look like but your best bet is to do this:
                        Remove the vacuum line going to the booster from the IM. Cap the nipple on the IM with rubber cap or many layers of electrical tape if necessary. Start the car back up and see if you can reproduce the high idle. If the high idle still happens then it IS NOT the brake booster, if high idle doesn't happen anymore then replace your booster, vacuum line, and check valve in the vacuum line....better to replace all these along with new booster.
                        Also: Boosters usually only go bad after the brake master cylinder leaks brake fluid inside the booster rusting it out and destroying seals.......so if the booster is bad it's very likely your master cylinder is leaking and needs replacing also.....when you remove the MC, if there is any wetness in and/or around the hole the mc rod enters the booster through then you have leaking brake fluid and the MC needs replacing.
                        Is the booster rusted at all? Are you losing brake fluid from the reservoir?
                        My Member's Ride Thread
                          Each time you hit the brake pedal the booster takes some vacuum. So if you repeatedly tap the pedal, you are effectively introducing a vacuum leak to the engine.
                            For a normal booster, you should only get a momentary slight rise (50 rpm?) in engine speed when the brake pedal is pressed. If you rapidly and repeatedly press the pedal, you can maintain this slight rise. If you step on the pedal and the idle increases to 2500, you have a substantial leak somewhere.
                              i meant if i step on i repeatedly it could increse to 2500 but if i step it once it goes up like 500rpm...
                              and ill check that booster to see what wrong
