clunking sound when stopping??
    I would recommend returning the $18 bearings for the $55 ones and stay away from the cheaper lower balljoints. Get the better quality stuff and you won't have to redo it in 6 months. Speaking from experience...
    short
      short
      there acually 38 but i get 60% off
        yeah bearings have to be pressed onto the hubs. I had to ask a guy w/ a 12 ton press to help me out. Then we had to cut the race off the old one w/ a dremel b/c it was stuck on the hub.
        I wouldn't cheap out on lower balljoints though. They're only 21 bucks a pop you can have both pretty much for a tank of gas.
        member's ride thread
        91 Accord SE 176k
          i did all my ball joints and i still have that cluncking sound 2. its not the ball joints. but if your tire is moving diffinetly change them. as far as the clunking sound when u come to a stop let me know, becouse im not sure what it is, my car has 270,000, i also get that rattling effect from the back when i hit a bumpy patch in the road, does any1 know what i'm talking about?
            has anyone said to look at the brake rotors ? also if the shock is worn out it will( clunk) as well. good luck man.
              i would also suggest looking at ALL the bushings. I know mine made a loud clunking due to the front sway bar link bushings going bad, mine were completely gone!
              91 Accord SE 176k
                This happened to me too, but it made the noise when I turned. The front right ones had almost no rubber.
                MRT
                sneaky motherfucker
                  inboard cv can also cause a clunk on accel/decel
                    I am not sure the exact name of the part but I think it is a radius rod. It leads from the front part of the car(radiator area) and attatches to the lower part of the Knuckle. The front portion has large Metal gasket looking parts and ruber parts. Check that a.s.a.p!
                    My car did the same to me when I had it. Just lay on the floor and see if you can wiggle it up and down or side to side.
                    CB7Tuner Resident Gamer!
                    PSN: JDMcb7TX
