Swap problem crazy honda rev 1500-5500?
    Ok so i crashed the accord and got a 94 prelude only to blow it up in 2 days. bought a 1997 h22a4 out of a guys prelude, got it in my car and its doing the stupid honda rev from 1500-5500 rpm. I have had this problem with my cb7 before and i ajusted that thing that always gets loose on the plentum. thats not it. anyone else have any idea?
    (I am using h22a4 with the h23a1 intake manifold, and h23a1 trans. i switched all the sensors that were different.)
    MIKE KOLODIEJ #11
    Stop crashing your cars?
    MRT
    sneaky motherfucker
      do you have lots of coolent?
        By "stupid Honda rev" I assume you mean an erratic idle (which is not a Honda-only thing at all...)
        I have no idea what "that thing in the plentum" is... plentum isn't even a word.
        Clean and adjust your FITV and IACV.
        Better yet, read the "sticky" thread at the top of the Technical section and find the thread about setting your base idle, written by HondaFan81. Follow the instructions, and you will fix your problem.
        How did you use an H23A1 intake manifold? It does not fit on the H22A...
        If you're not going to help, don't post... or you will find yourself banned, very quickly.
          thanks, and i know that its not just a honda thing however where i live there is alot of hondas that do it so its known as honda rev lol and i said usdm-h22a4 not jdm-h22a
          MIKE KOLODIEJ #11
            There are just a lot of Honda owners that don't know how to maintain their vehicles...
            It makes no difference between the H22A4 and JDM H22A... the H23A1 intake manifold does not fit.
              I have exactly the same issue. Will be following this.
              this is my thread
              http://www.cb7tuner.com/vbb/showthread.php?t=169195
              i'm going to try to bleed the coolant and check for vacuum leaks
                Did you bother looking at the sticky that shows how to fix an erratic idle?
