lol I was using the term "golden" as sacred and not gold in color.
How to clean an engine
Retro!
Hater
Originally posted by quaidum View Postgolden is a sign of the oil burning and tarnishing the metal
it should look like a piece of aluminum, grayish kinda
to thoroughly clean it would require you to disassemble the motor, cleaning the inside of a motor isn't often a regular maintenance thing
i would recommend you take the oil pan off first(you will need to replace the gasket) to see how much actual buildup there is. there could be very little there could be a lot, i have taken apart 3 different f22 and none of them were sludged up at all. all of them where in various conditions as wellMRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
