How to clean an engine
    lol I was using the term "golden" as sacred and not gold in color.
    Retro!
    Hater
      Originally posted by quaidum View Post
      golden is a sign of the oil burning and tarnishing the metal
      it should look like a piece of aluminum, grayish kinda
      to thoroughly clean it would require you to disassemble the motor, cleaning the inside of a motor isn't often a regular maintenance thing
      i would recommend you take the oil pan off first(you will need to replace the gasket) to see how much actual buildup there is. there could be very little there could be a lot, i have taken apart 3 different f22 and none of them were sludged up at all. all of them where in various conditions as well
      I changed my oil pan seal, the insides looked orangish-tan. Is that bad? I told a few people that and they said that's how it should look
      MRT
      sneaky motherfucker
