What can i use from Prelude for 5spd swap??
    obviously the trans and mounts are at the top of the list.
    but what else on this list can i take from the Prelude?
    http://www.cb7tuner.com/vbb/showthread.php?t=588
    im guessing all of the clutch parts minus the pedal. im not sure if it's the same.
      thats what i was thinking.
      pedals would be easy to find at the junkyard.
      if i can pull almost everything from a prelude that would be ideal.
        I can't recall if the master cylinder would work... but the cables will. The pedals may. The slave cylinder will. The trans, clutch, flywheel... obviously.
        The shifter setup will work, but may require some creativity to get it right.
        The lines may be different. You might need to get the CB lines.
          just about everything minus the axles. lines, shifter, cylinders, cables, etc all work
            I bought a 92 prelude si parts car this winter and used everything except the axles like cp[mike] said. Gonna need to pursuade the pedals to fit. just a small challenge but it will fit.
            93 Accord SE
            02 Highlander Limited
              goddam mike!!
              you keep telling me all the things i wanna hear.
              i owe you a beer.
              thanks guys
